98 blazer 4x4 in and out of overdrive
Old Apr 25, 2010 | 06:04 PM
shawn89's Avatar
shawn89 is on a distinguished road
I'm pretty sure the brake lights are working proberly. Another thing is if I shift it into 3rd the rmp will raise about 200-300rpm then if I shift it back into drive it will go back down to 2krpm at 65mph like it should be when the overdrive is in.
Old Apr 25, 2010 | 06:38 PM
That sounds more like it is shifting down to 3rd gear, but maintaining torque converter lockup. This could be caused by a problem with the 1-2 shift solenoid which is off in 3rd and on in 4th. If there is something causing this to drop out when you are off the throttle, it would cause a drop to 3rd gear.
Old Apr 25, 2010 | 07:03 PM
shawn89's Avatar
I see. I'm pretty mechanicly inclind but how do I go into changing the soleniods myself?
Old Apr 25, 2010 | 07:04 PM
It may not be a problem with the solenoid per say, but the circuit that controls it. You really won't know until you get it properly diagnosed. That is something that is VERY difficult to do without access to the vehicle (i.e. from across the internet).
Old May 27, 2010 | 09:09 PM
blazer073's Avatar
blazer073 is on a distinguished road
Good info I have been having this happen to me too. Any time between 40-60 MPH I can see the RPMs bounce between 1.5k-2k. I will try to get a video or somthing of this happening.
Old May 28, 2010 | 05:46 AM
Grillzy's Avatar
Grillzy is on a distinguished road
Unplug your 4wheel drive module (passenger side kick plate) bet the problem goes away. Let me know what happens.
Grillzy
Old Jun 2, 2010 | 01:06 AM
blazer073's Avatar
Ok so here is a video I took the other day of me driving to work. It's kinda long but what I am talking about happens at around 23 seconds into the video. I was on a pretty level road with cruise control set at 50 mph.
http://i10.photobucket.com/albums/a1...ent=blazer.flv
Old Jun 2, 2010 | 05:43 AM
Grillzy's Avatar
Forget my last post - not what I was thinking
Grillzy
Old Jun 2, 2010 | 06:15 AM
blazer073, that little bit of change could just be the PCM altering the TCC lockup for the conditions. 50mph is a 'tweener' speed where the TCC first starts to lock up when cruising, but may unlock given calculated engine load. Does it do this while you are running at say 55mph or 60mph on smooth level ground?
Old Jun 2, 2010 | 04:56 PM
shawn89's Avatar
Mine will do it at any speed even up to 90mph
