98 Blazer timing chain cover replacement
Old Mar 25, 2010 | 10:03 AM
gabenton's Avatar
gabenton is on a distinguished road
Default 98 Blazer timing chain cover replacement
I am replacing the timing chain and cover on my 98 Blazer, 4.3 eng. I have gotten everything off ok and have replaced the chain ok. But I am having trouble getting the cover back on. The rubber oil pan gasket at the bottom is preventing the cover from going back on. Haynes says to loosen front 3 oil pan bolts on each side, which I have done, but can't break the pan loose from the block. Any suggestions on how to do this?
Old Mar 25, 2010 | 10:08 AM
I would loosen all of the pan bolts (don't forget the ones up inside the bell housing). Your aluminum pan doesn't flex like the old stamped steel pans did. That should allow you to drop the pan down enough to get the cover in.
How did you get the cover out? Hopefully you didn't damage the pan o-ring.
Old Mar 25, 2010 | 12:47 PM
gabenton's Avatar
The plastic timing cover flexed enough to come out and the o ring seems to be fine.
Old Mar 26, 2010 | 08:23 AM
Willwag3's Avatar
Willwag3 is on a distinguished road
You`ll have to drop the oil pan all the way. before getting in to all that take a look at youre timing tab. Is it in the 2 o`clock position or 12? I changed a timing cover and wound up having to change balancer out too. My pointer was 12 o`clock with a 6 3/4 balancer and couldn`t get a replacement tab to fit in proper position. Had to go to larger balancer so I could have a tab.
Tan2001BlazerLS
Jan 30, 2013 10:37 AM
drblaze
18
Jun 22, 2011 01:58 PM
Bonedaddy
Jul 6, 2010 05:14 PM
CDJr
May 21, 2009 01:43 PM
black95blazer
Jan 30, 2008 05:01 PM
