98 Blazer won't accelerate
Old Nov 19, 2007 | 07:50 PM
THSteve's Avatar
THSteve is an unknown quantity at this point
Default 98 Blazer won't accelerate
I own a 98 Blazer LS with about 67,000 miles on it. I just bought it a few months ago and everything was fine until a few days ago when I got on the highway and it was very hard to accelerate. If I let of the gas a little the engine would get fuel but as soon as I would press on it a little harder it wouldn't do anything. After I pulled over and looked under the hood for a few minutes it started up and ran fine for a little bit and ended up doing the same thing. Also, I've noticed that a few days prior it has been hard to start. I'm thinking fuel filter.....any suggestions?
Old Nov 19, 2007 | 08:46 PM
Idriveachevy's Avatar
Idriveachevy is an unknown quantity at this point
Default RE: 98 Blazer won't accelerate
Im having a similar problem right now, it feels like its holding back, i let off the gas and then get back on it and it goes fine. i thought it could be fuel or air filters?
Old Nov 19, 2007 | 10:35 PM
THSteve's Avatar
I'm pretty sure its not my air filter because I couldn't go over 20 mph. I'm hoping its just the fuel filter because replacing the pump would be horrible timing considering the holidays are coming.
Old Nov 19, 2007 | 11:04 PM
Chevy Lover's Avatar
If you haven't changed the fuel filter for a while it's not a bad idea to do so. When you change the filter, tap out the fuel onto a white rag and see if you see any black in the fuel. Black in the fuel filter is an indication of wear in the fuel pump ( black carbon brushes)
Old Nov 21, 2007 | 05:10 PM
THSteve's Avatar
Changed the filter and I still have the same problem. The acceleration problem only happens after I drive for a little while. If I stop the truck for a minute it drives fine and eventually happens again. Also, when I pulled the old filter I notced lots of black in my fuel line.
Old Nov 21, 2007 | 09:17 PM
SMALLBLOCKHERO's Avatar
SMALLBLOCKHERO is an unknown quantity at this point
amazing!..im having the same prob on my 97. feels like the converter is locking up and when i shut down the vehicle it unlocks till i get to like 40 mph. the 4.3 feels like its straining against the converter.
914door
Oct 13, 2011 04:34 PM
MXer746
Jun 6, 2011 02:34 PM
marrand3
Nov 11, 2009 05:01 PM
Jer12
Mar 28, 2007 07:11 PM
budiblazer
Jun 21, 2006 09:57 PM
