98 Bravada front drive shaft
Old Jun 17, 2021 | 06:15 AM
reed's Avatar
reed is on a distinguished road
Default 98 Bravada front drive shaft
Hi , Im new to this group so go easy on me , I have a 98 bravada that I'm wanting to take the front drive shaft out so i can pull it with a toe dolly , I do understand pulling it with a toe dolly will ruin the transmission and some other components , Any idea how hard it would be to take it out and will it hurt anything , Thanks in advance
Old Jun 17, 2021 | 01:26 PM
Wouldn't you want to take the rear driveshaft out to tow it on a dolly? Just unbolt it at the rear differential, then tie it up (securely) so it doesn't fall down or slip out of the transfer case. Obviously, you'll need to reinstall it when you get to where you're going.
And you'd probably be better off posting your question in the correct section, rather than the New Member Area.
justice4x4
Jun 30, 2015 11:38 PM
Brandonrcm
Sep 11, 2013 12:01 AM
CodeyBravada97
Apr 8, 2013 09:02 AM
chcknugget
Oct 24, 2012 08:25 AM
nsomnia_redline
15
Apr 29, 2009 08:37 AM
