98 engine to 2000 question
Old Mar 27, 2021 | 10:19 AM
dgriffinhere's Avatar
dgriffinhere is on a distinguished road
Default 98 engine to 2000 question
am swapping out my 98 seized engine for a 2000. everything is going good but have noticed a difference in timing chain and sprockets. the 98 has the factory assembly which is a double row chain and wide sprockets. the 2000 engine has a single row chain and slimmer sprockets. the 98 engine's timing set is pristine. there is almost no deflection in the chain. the 2000 engine has a fair amount.......2 questions...can i switch out the sprockets and use the 98 set up on my 2000 engine?......and why not use the timing cover again with a new gasket??? thanks in advance for any answer....david g. ps both have balance shaft.
Old Mar 27, 2021 | 10:39 AM
LesMyer's Avatar
photos please
Old Mar 27, 2021 | 12:09 PM
LesMyer's Avatar
There was no double row timing chains in balance shaft engines. There was a change in timing chain components from 1998 to 2000.
Look at Melling's parts look up.
1998 takes 3-499 timing set.
2000 takes 3-8mmSRH72SB set (which is an upgrade for 3-499 set - has a tensioner)
89017259 timing cover is required for 3-8mmSRH72SB. So use the 2000 parts if you are going to replace them.
Old Mar 28, 2021 | 11:31 PM
Mods's Avatar
Originally Posted by LesMyer
photos please
seconding this, if we could fit a double row chain i'd be all over that. actually in theory wont a normal SBC 5.3 Double Row fit on these since they share basically all components? might be clearence issues with the timing cover but,
dgriffinhere
Mar 10, 2021 11:40 AM
98moneypit
Aug 1, 2014 11:16 AM
blazersaver
Feb 2, 2013 07:11 PM
geffert
Dec 5, 2010 05:10 PM
dpannazzo
15
Dec 17, 2009 01:18 PM
