'99 4.3 to 700r4
I've got a '99 4.3 swapped into a Jeep, I'm currently running an NV3500 but the case is cracked and I'm thinking about going to a 700r4. Does anyone know what I need to make it work?
You'll need a flexplate and some way to hook up the TV cable. You'll want to add a transmission cooler. Also the correct adapter for your transfer case. I have no idea if the driveshafts will end up the right length or not. Other than that, I think it's pretty straightforward.
Originally Posted by Tom A
(Post 729192)
What type fuel induction are you using? Carb, TBI, injectors. Will determine what set up you need for the correct geometry.
Brad |
