'99 4.3 to 700r4
Old Nov 16, 2020 | 01:01 PM
ZachC540's Avatar
ZachC540 is on a distinguished road
Default '99 4.3 to 700r4
I've got a '99 4.3 swapped into a Jeep, I'm currently running an NV3500 but the case is cracked and I'm thinking about going to a 700r4. Does anyone know what I need to make it work?
Old Nov 16, 2020 | 07:01 PM
You'll need a flexplate and some way to hook up the TV cable. You'll want to add a transmission cooler. Also the correct adapter for your transfer case. I have no idea if the driveshafts will end up the right length or not. Other than that, I think it's pretty straightforward.
Old Nov 17, 2020 | 05:15 AM
ZachC540's Avatar
That's basically what I figured, my main concern is getting the TV cable to work. I'm hoping someone on here has done this before and can shed some light on it.
Old Nov 17, 2020 | 08:29 AM
Transman304's Avatar
What type fuel induction are you using? Carb, TBI, injectors. Will determine what set up you need for the correct geometry.
Brad
c.clark.24
Mar 19, 2012 04:14 PM
Katmandu
Jan 15, 2010 06:55 PM
instygator
Feb 22, 2009 06:59 PM
nasir
Nov 10, 2008 06:20 PM
black99xtreme
May 8, 2007 12:55 PM
