99 4.3 swap help!?! newbie
Old May 15, 2010 | 10:18 PM
lesakflooring's Avatar
lesakflooring is on a distinguished road
Default 99 4.3 swap help!?! newbie
I have been looking for a replacement motor for my blazer. All the j yards tell me is that a 99 only swaps with a 99. Is this true or can I use anything close? I will be swapping most everything over to the newer motor and installing a new oil pump and water pump. So I am confused as to why that year is so special or have I received bad information?
Old May 15, 2010 | 10:30 PM
Dan 128's Avatar
Dan 128 is on a distinguished road
Default Motor Swaps!
All I can say is do you homework before you buy. I have a 2000 S-10 Blazer and I was told the same thing. I ended up picking up a 2000 Bravado motor only to find that it uses a different timing chain than my original motor. I'm experiencing a running issue that sends no codes but the scanner is showing that the motor is running 12 degrees retarded and should be running at 0 degrees.
After Q&A's for the past 4 weeks I learned the timing chain differences and to think I was going to put in a new one before installing the motor. I'm still not sure if this is the problem, but it sure would have been an easier job outside the engine bay. So yah, get the same year and model or do your homework.
Philipx
Nov 3, 2011 10:36 PM
TylerK10
Sep 22, 2011 10:31 PM
zynnad
Nov 4, 2009 09:09 AM
CorrosiveMind103
Nov 7, 2007 08:03 PM
TheDesertFox
May 2, 2006 09:18 PM
