99 Blazer: engine dies when engine is hot
Old Oct 23, 2008 | 02:09 PM
johinut's Avatar
johinut is an unknown quantity at this point
Default 99 Blazer: engine dies when engine is hot
I have had this happen a couple times to me but when I have driven my blazer up a long hill or under load, the engine temp is above normal and after driving about a solid hour, the engine will just shut off.
It will restart but only after about a 20 min wait. during this time I would attempt to restart the vehicle but I do not hear the fuel pump pressurizing. Only after the wait do I get the pump noise, which is fairly loud, but it does restart. During normal driving, it operates great.
My question is, does it sound like it would be as simple as the fuel pump needs to be replaced or could it be something more systemic? After vehicle gets hot (not like burn up the motor hot, just higher than normal from hard climbing), it is shutting down the fuel pump or just shutting down the vehicle?
Any ideas or suggestions onthis?
Old Oct 24, 2008 | 02:54 PM
ant2297's Avatar
ant2297 is an unknown quantity at this point
Default RE: 99 Blazer: engine dies when engine is hot
bad coolant temp sensor it sounds like.
Old Oct 24, 2008 | 04:06 PM
Hanr3's Avatar
Have your fuel pressue tested, although based on oyur description of hte noisey fuel pump its about to go.
another option and could be the cause of your problem is the ICM, early signs its about dead is failure when hot. Once cool it works like normal. Good news is that most autoparts stores can test it. Make sure to put new grease behind it. The grease aids in coolign it down. So does th heat sink it is attached too. Got any exhaust leaks on the passengers side? They could be heating it up too.
pdewey
Aug 25, 2011 02:43 PM
Mandrwj
Apr 10, 2011 07:32 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
Poligono
Nov 3, 2008 06:01 PM
clay1937
Oct 28, 2007 10:44 AM
