99 Blazer overheated blown head gaskets?
Old Jul 11, 2009 | 12:13 AM
Blazer1999ls's Avatar
Blazer1999ls is on a distinguished road
Default 99 Blazer overheated blown head gaskets?
Will I purchased a 99 blazer and it overheated it has water in the oil and is blowing white smoke, could it be a intake gasket problem or headgasket problem? Idles like crap. Thanks.
Old Jul 11, 2009 | 02:15 AM
bandidolenny's Avatar
Yep, I bet is does idle like crap... don't run it too much or you could mess up other things like the cat and oxygen sensors.
My guess is the previous owner covered this problem up and sent it on down the line... but that is pure speculation on my part.
If it were my truck, I would just go ahead and pull the heads too... it's really not that much more work and then there's no doubts in the back of your head when you put it all back together.
Old Jul 11, 2009 | 09:31 AM
Should I have the heads resurfaced or should I just install the head gaskets and scrape the cylinder heads clean?
Old Jul 11, 2009 | 09:36 AM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
IMO i would have them checked and a valve job done for peace of mind..around here it's only 10 bucks per cylinder 60 bucks to do both heads.. check with your local machine shop ..It's Just an idea.
Old Jul 11, 2009 | 04:24 PM
well i started on it but how the heck do you get the fan off my car has ac i unbolted every screw on that dam fan and it won't come off!
Old Jul 11, 2009 | 04:46 PM
BigBadHoe's Avatar
BigBadHoe is on a distinguished road
Use a shallow outside puller, and a box end wrench.
Old Jul 11, 2009 | 05:08 PM
thanks which way is to loosen it counter clockwise or clockwise?
I put a steering wheel puller on the pully itself so I can hold it in place and use a large wrench to turn it, is that right?
Old Jul 11, 2009 | 06:12 PM
reelbroke2's Avatar
what pulley are you removing? The fan is bolted to the water pump and should pull right off once you have the nuts removed from the studs
Old Jul 11, 2009 | 06:18 PM
Fan thread is regular righty tighty, lefty loosey.
The fan actually threads onto the snout of the water pump. The pulley is what is bolted on. Removing the for fasteners on the pulley will not remove the fan/clutch assembly.
Old Jul 11, 2009 | 06:21 PM
reelbroke2's Avatar
My Bad!! I was thinking it was set up like mine..sorry..lol
