99 blazer wont start
Old May 12, 2012 | 12:37 PM
killingfloor's Avatar
killingfloor is on a distinguished road
Default 99 blazer wont start
hi folks i was going down the road my truck shut off and will not start changed map sensor iac sensor nothing the truck turns over but wont start i put starting fluid in and nothing im at wits end with this truck any help would be really appreciated thanx kf
Old May 12, 2012 | 12:50 PM
50lb_cat's Avatar
I would start with a fuel pressure/leakdown test. Make sure the battery has good contact, check plug wires,etc. ,could also be the tps.
Old May 12, 2012 | 02:56 PM
tps? thanx for reply
Old May 12, 2012 | 03:26 PM
50lb_cat's Avatar
That's the throttle position sensor, I would still start with a fuel pressure test. There's a good write up in the diy section.
Old May 12, 2012 | 03:36 PM
leester480's Avatar
leester480 is on a distinguished road
i'd bet money your control module crapped out.there are many possibilities for this symptom.Possibly your timing chain has broken.You could have a blocked fuel filter and the list goes on and on.Try spraying starting fluid into the air intake while cranking it, if it fires it would take the broken timing chain and ignition system issues partially out of the way.It maybe the fuel pump has failed you would remove the supply line to your Throttle body or fuel injectors and run the line into an empty bottle as soon as you turn the switch on you should see an stream of fuel coming into the bottle.Buy a Haynes manual(Autozone $25.00) if you want to make these repairs yourself.You'll gain some practical automotive knowledge and save yourself some serious green!!!
Old May 12, 2012 | 04:02 PM
50lb_cat's Avatar
IMO, I can't recall ever seeing a broken timing chain in a 4.3. The haynes and chilton manuals are ok but you can create an account at autozone.com and get free repair guides.
Old May 12, 2012 | 06:23 PM
98BlazerSL's Avatar
98BlazerSL is on a distinguished road
Check the spark at the plug wires. if it is anything other then a strong blue try changing the cap and rotor button. an easy way to check the timing chain is to remove the distrib. cap and have some one crank the engine. If the rotor button turns the chain is good. I'm not sure how to link it but there is a thread flowchart here somewhere to try and determine the cause of the problems.
dj00140
May 20, 2013 06:37 PM
JimmyBlaze541
May 2, 2013 10:00 AM
bobby099
15
Nov 7, 2012 07:29 PM
FreeTime
Sep 8, 2012 01:38 AM
jetsmy
Aug 1, 2008 10:10 PM
