99 Olds Bravada trans
hey, all!
The trans in our 99 Bravada lost 4th gear. Would a 4x4 trans from a 98 blazer fit? (since Bravada is an AWD)
Thank you, guys!
Thank you, guys!
Yep, but you have to use the Bravada's transfer.Hope this helps and Good Luck with the swap.
our service awd light has been on for a while, it didn't engage all 4 wheels this winter. does that mean the case or motor is toast? would a fluid change help?
the trans i'm looking at has its own transfer case, but will it work instead of the awd one we have?
thank you!
thank you!
guys, would a 2001 bravada trans fit? found one with around 100k. thank you!
NC93BLAZERLT
21
12-30-2008 05:23 PM
93LT
01-09-2006 09:25 PM
