99 throttle body plug issues
Old Nov 24, 2013 | 09:00 PM
beast1978's Avatar
beast1978 is on a distinguished road
Default 99 throttle body plug issues
I have had a problem with the secondary air pump since I built the truck last year so I decided to check all the wiring. I guess while looking around I bumped the throttle body electrical plug and she wouldnt start after that. I figured out the plug wasnt seated fully so I pushed it as far as i could but the trucks not running right. trucks stinking like raw fuel and running rough. Long story short any thoughts on how to get the plug to seat properly because Im close to breaking it and dont want that. thanks in advance
Old Nov 24, 2013 | 10:01 PM
richphotos's Avatar
check your fuel pressure, Do a fuel pressure and leak down test.
Old Nov 25, 2013 | 11:03 AM
iian's Avatar
iian is on a distinguished road
I would check to make sure the male parts of the pin is straight. If any of those are bent they will not go into the female connector and will do what you are describing.
Old Nov 27, 2013 | 10:50 AM
beast1978's Avatar
I did a leak down and that checks out okthanks for your input. Hope i figure out something soon
Old Nov 27, 2013 | 11:06 AM
beast1978's Avatar
I pullee the plug and checked the pins. They all seem straight but i found something im not sure about. It has two seals on it, one orange and one blue. The blue one looks new but the orange one seems old and has a tear 3/4 the way through. Im guessing someone put on the blue one and left the old one thinking they were double protected. I got it to clip on one side but not the other side so im want to take off the torn orange seal. Any thoughts?
futuredoc
Oct 7, 2024 06:14 PM
4.3l trouble
Apr 7, 2019 06:54 PM
boulonman
Mar 5, 2007 05:10 AM
02 Vortech
Engine & Internal
Mar 13, 2005 11:20 PM
94Blaze
Engine & Internal
Jan 5, 2005 09:59 PM
