When I shift the tranny from park through all the gears the motor either idles up high or sometimes innuetral it bogs down and dies not sure what could be causing this,, also when I press on the brakes it does the same thing. Any ideas.
RE: ???
The likely cause of your stalling is a vacuum leak which could be caused by a faulty vacuum booster.
One other suggestion. Please try to title your threads with something more descriptive... |
RE: ???
Is there another name for this "vacuum booster"? I cannot find it at any store. Thanks
RE: ???
You need to find the cause of the vacuum leak. Please do not just go buy parts and throw them at your truck... If it is the vacuum booster (aka brake booster - located between the brake master cylinder and the firewall), then replace it.
To test, run the engine, then shut it off. Wait a minute or two, then remove the vacuum line (check valve and all) from the front of the brake booster. If you do not hear a woosh of air being sucked into the brake booster, then the booster and/or check valve is bad. You could try replacing the check valve first (cheap enough). If the results are the same, then the booster is bad. To check for other vacuum leaks, I use an unlit propane torch and listen for changes in engine RPM as I trace along the vacuum lines with the torch tip. The propane being sucked into a vacuum leak should cause the engine RPM to change. |
