Advise needed for water pump
Old Jul 20, 2010 | 07:31 AM
chevyblazer's Avatar
chevyblazer is an unknown quantity at this point
Default Advise needed for water pump
Mine is a 95 Blazer, which adopts many mechanical parts from other very old siblings from 80's, and makes huge differences from 96-05 blazer models. The OE water pump for 95 model is AC Delco 252-719, and 96 + models uses AC Declo 252-711.
At present, the engine always runs overheated, and found the coolant leaks from the water pump in large amount. Need buy a new replacement, however, 95 model's pump is difficult to source in my area, and AC delco's staff declined to tell if these two models are interchangeable, anybody has any idea or suggestion to help? or does it mean i have to rebuild the entire cooling sys, including clutch, fans, hoses, even radiator instead of replacing a single pump???
Thanx in advance!
Chevyblazer
Old Jul 20, 2010 | 12:09 PM
rusty91's Avatar
rusty91 is an unknown quantity at this point
i got a pump from advance auto online they have a heavy duty one same price as a standard pump have 10k with no problems on my 95 also replace your thermastat
Old Jul 20, 2010 | 12:20 PM
rusty91, thank you so much for the info, and i was afraid that nobody could get me a reply, coz the question seems a little weird, again, i appreicate your help!
chevyblazer
das96blazer
Jun 2, 2011 08:55 PM
chevyblazer
Oct 23, 2010 07:38 PM
Skinkutter
Jul 22, 2009 04:34 PM
dustinm417
Aug 23, 2006 09:49 PM
blazer85
Nov 18, 2005 04:41 PM
