need your brake advise!!!!!!!!!!
Old Nov 14, 2005 | 03:12 PM
blazer85's Avatar
blazer85 is an unknown quantity at this point
Default need your brake advise!!!!!!!!!!
hi all i a have a 2000 4dr 4x4 blazer that i recently tried to do the rear brakes on(disc). i foolishly let all of the brake fluid drain out of the master cylinder b/c they gave me the wrong pads and i had to go back to the store. anyway i have gravity bleed the brakes and i am not getting any air to the rear bleeders, i am getting all fluid, but no pressure. the pedal is still staying soft and the fluid coming out of the bleeders has no pressure, it just kinda comes out if you understand what i am saying.....any help would be really appreciated
thanks
p.s. i replaced the rotors calipers and pads
Old Nov 18, 2005 | 03:57 PM
Hanr3's Avatar
Default RE: need your brake advise!!!!!!!!!!
I think you need to bleed the master clyindar too. Look it up in the Hanyes manual. Should have instructions on how to do it.
The other thing, and what really might be your problem, your POSITIVE you didn't twist one or both of the brake hoses when you put the caliper back on?????
How did you lose brake fluid by changing pads? I don't understand that part at all.
Old Nov 18, 2005 | 04:41 PM
blazer85's Avatar
i had to replace all of the parts sorry i forgot about that part rotors, pads, calipers, hoses...also there is no bleeder on the master cylinder or the electronic brake control module......and i had the hose off when i ran to the store to get the right pads
thanks
spyderlock
Lifting Tech
Feb 10, 2010 08:08 PM
ben512v
Aug 15, 2009 12:02 AM
94S10
Nov 18, 2007 12:26 PM
Blindthieves
Oct 28, 2007 06:35 PM
dustinm417
Aug 23, 2006 09:49 PM
