Air pump question
Old May 9, 2012 | 12:31 AM
linsgm's Avatar
linsgm is on a distinguished road
Default Air pump question
does a 92 blazer s10 4.3 vortec have an air pump and if yes what does it do or is it for
Old May 9, 2012 | 07:45 PM
failed emissions's Avatar
failed emissions is on a distinguished road
My 88 s10 blazer 4x4 2.8 has an air pump. Also called a smog pump. It forces air into exhaust manifold to help burn unburnt fuel. Cleans the emissions. You probably have one. Drivebelt turns the pump. A line goes to a check valve and then goes to the manifold. Mine is on the passenger side of engine. Hope this helps
Old May 9, 2012 | 08:26 PM
neo71665's Avatar
Old May 9, 2012 | 08:33 PM
chris015's Avatar
yours does not have a a.i.r pump. Usually the older pre 90's one have em.
Old Oct 1, 2012 | 06:11 AM
dbshortwave's Avatar
dbshortwave is on a distinguished road
some of the 2000 series GMC or Chevy has smog equipment. my 2000 Jimmy has an electric A.I.R. pump kinda sucks when it throws a check engine code.
Old Oct 31, 2012 | 08:06 PM
beast1978's Avatar
beast1978 is on a distinguished road
does a bad secondary air pump cause hard starts?
Old Nov 1, 2012 | 10:27 AM
No, hard starts could be cause by many things. Timing, fuel, tune up past due, fuel pump, the list is endless. Start with the simple. But brows the forums for more info on hard starts.
BouncingRadical
14
Nov 27, 2015 12:30 AM
Mtucc
Aug 5, 2012 06:21 PM
CompTechMike
Feb 26, 2011 02:46 PM
jojocarreno
Jul 1, 2010 07:30 PM
dimmuborgir6nik6
Oct 2, 2008 06:51 AM
