ANOTHER HEATER CORE QUESTION!
Old Apr 11, 2007 | 10:41 PM
98blkblzr's Avatar
98blkblzr is an unknown quantity at this point
Default ANOTHER HEATER CORE QUESTION!
I NOTICED TODAY THAT MY 98BLAZER I BOUGHT IN FEBRUARY HAS HAD AT LEAST ONE CORE REPLACED ALREADY, DUE TO THE HOSE CLAMPS I SAW. I TALKED TO ONE GUY WHO SAID HE HAD A TAHOE THAT ATE 7 CORES IN THREE MONTHS! HE WAS TOLD BY A DEALER THAT SOMEHOW ELECTRICAL CURRENT WAS PASSING THRU THE CORE, CAUSING MASSIVE CORROSION. ARE THERE OTHER THINGS TO LOOK FOR TO PREVENT MY NEW CORE FROM GOING BAD? THANKS. RON
Old Apr 11, 2007 | 11:01 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: ANOTHER HEATER CORE QUESTION!
You can measure for voltage in your coolant with a standard volmeter...just stick one lead on the negative side of the battery and submerge the other lead in the radiator if you read more than .1 Volts DC then you haveexcessive voltage in the cooling system...if that's the case run a ground wire to the heater core pipe and it should prevent any damage. This is a common problem in fords, but I have never seen it once in a G.M. vehicle. Just because you have new hose clamps doesn't mean that the heater core was replaced by-the-way. It's quite possible someone was trying to flush it out and replaced the clamps.
Old Apr 12, 2007 | 12:51 AM
98blkblzr's Avatar
man, sounds like you've been doing this a while! thanks for being so knowledgeable, i appreciate it! Ron
Old Apr 12, 2007 | 03:05 PM
lastcoupe's Avatar
LOL...always glad to help someone who appreciates it....
kng254
Jan 2, 2011 11:24 AM
jstein
Feb 22, 2010 01:09 AM
KdogTN
Sep 28, 2008 05:18 PM
black19
Dec 26, 2006 09:18 PM
ericmiller5000
Dec 13, 2005 01:26 PM
