Automatic Transmission Flush
Old Apr 3, 2011 | 11:05 AM
karmafuzion's Avatar
karmafuzion is on a distinguished road
Default Hows the fluid look
If the trans fluid is still pink and still smells like trans fluid then your good, leave it alone. If its starting to go brown and looses that great trans fluid smell, it's time to change. Changing the filter and fluid by dropping the pan is ok and the way I've always done it up to a few years back. Now they have these pump/machines that run at operating pressure that work like a blood transfusion. The new goes in as the old comes out, replacing ALL the transmission fluid. When you change it by removing the pan, you only get some of the old dirty fluid out. These newer machines do a thorough job and only costs about 100.00 at a brake/muffler shop.
Old Apr 4, 2011 | 01:40 PM
qsecofr's Avatar
qsecofr is on a distinguished road
Is it the lower line at the radiator that is the feed line on a Blazer LT -97? (4l60e)
So is it just to unbolt it and connect a suitable hose to it and starting to pump the oil out?
And of course re-fill new oil after about 2 quarts as described earlier?
Thanks,
/qsec
hroofblaze96
Jan 15, 2020 04:39 PM
pfsantos
Sep 23, 2010 03:58 PM
portcqb
Apr 29, 2008 09:56 AM
Chadoo951
Dec 27, 2007 04:42 PM
ZR 2
Dec 4, 2007 03:53 AM
