balance shaft and timing chain
Old Oct 16, 2008 | 08:47 PM
4speed's Avatar
4speed is an unknown quantity at this point
Default balance shaft and timing chain
can the balance shaft be eliminated?
is the timing chain for the 4.3 the same as the sbc.
the motor i have is a 98 vortec.
can i just swap intake manifolds from a 95 to 98? are they the same motors except for the intake?
thank you
Old Oct 16, 2008 | 09:38 PM
Default RE: balance shaft and timing chain
What would be the motivation for removing the balance shaft?
You could check timing set numbers from various websites... Seeing as how it has the balance shaft, I would initially say that it would not be the same.
You cannot swap the intake from a 95 to a 98. The bolts are vertical in the 98, they are perpendicular to the intake to head interface on the 95.
piscespokerbrat
Apr 21, 2012 11:58 AM
Chevy33
Nov 28, 2011 08:32 AM
drblaze
18
Jun 22, 2011 01:58 PM
noon_crue
Jul 19, 2009 08:39 PM
brunosrk
Sep 21, 2007 02:58 PM
