Battery or foglights?
Old May 2, 2009 | 02:40 PM
nyzr21019's Avatar
nyzr21019 is on a distinguished road
Default Battery or foglights?
so after buying my 2001 Zr2 from the dealership tuesday, yesterday i was driving and after i went to get something for 5 minutes i came back and the truck wouldnt start, i luckly got a jump and it started, i havent started it at all today but i dont know what it could be is it the battery? is it the alternator not holding charge? my other theory was i have 2 PIAA foglights could that be draining the battery, but i only have them on when i drive, any idea on what its is? are they wired wrong?
Old May 2, 2009 | 04:31 PM
okvortec's Avatar
How old is the current battery? Do the lights run continuously or are they hooked up to a switch? I'd try buying a new battery, and if that one drains too, test/replace the alternator.
Old May 4, 2009 | 06:11 PM
kwacasey's Avatar
kwacasey is on a distinguished road
you can put a current meter in line with the positive battery terminal (10AMP scale preferred) and check the current draw yourself, (with the truck off ) that will tell you if you have a constant current draw problem. You can also disconnect the negative battery terminal while the truck is running, if it dies then the alternator is bad (because it would prove that it was running off the battery at that time).
I would try those two things, maybe they will point you in the correct direction.
XBlazer01
Aug 14, 2006 07:39 PM
blazerxtreme1
Jul 31, 2006 04:08 PM
Bojib
Jun 10, 2006 10:30 PM
BlazerChick
Feb 19, 2006 04:41 AM
XBlazer01
Feb 14, 2006 09:09 AM
