Beating a dead Horse. 4.3 1998 blazer 4x4
Old Apr 11, 2024 | 02:48 PM
  #31
GrilledCobra's Avatar
GrilledCobra is on a distinguished road
[QUOTE=GeorgeLG;752600]Yes, your problem is in the intake manifold.
George[/QUOTE
Spiders connected at 11:20 55psi only
1121 psi is at 54
1122 psi 54
1123 psi 54
1124 psi 54... Looking like spiders are holding but not the 66 - 60.
1127 psi 53
1129 started raining so ended test we are at 51psi with spiders connected.
Old Apr 11, 2024 | 03:20 PM
  #32
GeorgeLG's Avatar
  1. What brand of injector spider did you install?
  2. Did the regulator get replaced?
  3. Why was the spider replaced initially?
George
Old Apr 11, 2024 | 04:09 PM
  #33
George
Got a set from partsgeek. It's the upgraded version without the tabs
it came as a full unit
Spiders were replaced because of a crack on spider for Cyl1 causing a miss fire. After taking them out almost all tabs were broken off and missing.
Just pulled intake off and cycling the pump resulted in NO leaking in intake. Nothing came out of pressure valve. Cycling pump 4 times for 2 seconds does not result in any leaks into intake.
I have cloth rags laying all over the intake and nothing is wet. Could the fuel pressure valve be bad but not leaking?
Old Apr 11, 2024 | 04:12 PM
  #34
GeorgeLG's Avatar
That leaves injector(s) leaking into the cylinders or the regulator. I suspect the regulator.
George
Old Apr 11, 2024 | 04:14 PM
  #35
George
Are you able to pull these injectors without messing up the stem?
Old Apr 11, 2024 | 04:18 PM
  #36
GeorgeLG's Avatar
I don't know, never tried it. If anyone else has experience on this pls chime in. I suspect the regulator because you don't leak down very much.
George
Old Apr 11, 2024 | 04:26 PM
  #37
George
Sucks I got to put the whole damn thing back together lol. Welp if it's the regular I'll get a del and hopefully that works. I have till the 30th to return these injectors.
Old Apr 11, 2024 | 04:33 PM
  #38
GeorgeLG's Avatar
A general comment for anyone else reading this.
This is one of the reasons that I don't like the parts cannon. You can actually add to your problems ripping out a perfectly good OEM AC Delco part and replacing it with a crappy aftermarket clone. If this happens and this was not the original issue, now you have two problems. Sometimes detailed analysis is impractical, especially for the shade tree mechanic and an educated guess is required but this should be kept to a minimum.
George
Old Apr 11, 2024 | 04:35 PM
  #39
George
The missfire was fixed after the swap. I have to wait till I get a nice pay because I'm just getting parts as I can afford them. 300$ for a unit is ridiculous but if I can find a good one used I'll pick it up. I have a few blazers and a Jimmy I know where their setting.
Old Apr 11, 2024 | 04:41 PM
  #40
GeorgeLG's Avatar
In your case you may very well have needed a spider but I am just driving the point home that a replacement does not automatically take that component off of the table. The infant mortality rate of parts store offshore replacements is significant.
George
