Before I start tearing into the motor.
Old Dec 19, 2007 | 04:01 PM
96Ls4Dr's Avatar
96Ls4Dr is an unknown quantity at this point
Default RE: Before I start tearing into the motor.
MAJOR PROBLEM!!!!!
I just drained my oil and it was a sludgy greenish brown....
Last time I checked it was last Wednesday and I just checked it with the dipstick and it was good. Could it have been bad this whole time or could it have just done this now?
What do I do now?
Old Dec 21, 2007 | 05:44 PM
Hanr3's Avatar
Check your rad fluid and see what it looks like?
Typically if you drive with anti-freeze in the oil it will turn white/brown.
Sounds like you may have had some anti-freee in the catch container and it floated to the top when the oil was put in it.
Old Dec 22, 2007 | 06:13 PM
96Ls4Dr's Avatar
Hanr... There is no antifreeze to check. I went and drained the oil to make sure there was no antifreeze in it and the greenish/brown sludge was what came out.
Old Dec 22, 2007 | 06:22 PM
96Ls4Dr's Avatar
Started taking the motor apart today... I've got it down to the heads and can't figure out how to get the headbolts that are under the exhaust out. I took the manifold bolts out but there isn't enough room to get to the headbolts. I tried to loosen the bolts where it connects to the rest of the exhaust but they wouldn't budge.
So I have the intake completely clean and all the gaskets changed on it. I'm just waiting on a way to get to the exhaust side headbolts.
Old Dec 26, 2007 | 11:03 PM
1990blackgt's Avatar
1990blackgt is an unknown quantity at this point
Get some PBlaster from your local auto parts store and spray the bolts holding the header to the rest of the exhaust system. Let that sit overnight......... The next day get a breaker bar, pipe, wrench around a 1/2 rachet, impact, whatever you need to break those bad boys loose. You don't NEED to remove the header, only loosen those bolts to move it over to get access to the lower head bolts. I just did this job myself....
Old Dec 26, 2007 | 11:06 PM
felonyblazer96's Avatar
felonyblazer96 is an unknown quantity at this point
your changing the intake gasket right?
Old Dec 27, 2007 | 04:36 PM
Hanr3's Avatar
ORIGINAL: 96Ls4Dr
greenish brown sludge sounds like you found your anti-freeze. It's mixed in with your oil.
Old Dec 28, 2007 | 03:40 PM
96Ls4Dr's Avatar
Yeah I changed the intake gasketsand headgaskets....
It's all back together except the manifolds to the exhaust, the fan and shroud and the airbox.
I had it running last night for 20-30min and never overheated or even reached 210. Actually went to the halfway mark between 100 and 210 and just went up onemark and back down.
shadow03
Aug 8, 2014 03:06 PM
Chris15379
Oct 1, 2012 11:14 PM
CraigSnedeker
Apr 14, 2010 09:59 AM
96Ls4Dr
Dec 14, 2007 07:17 AM
flyinbrad
Jan 14, 2007 03:01 AM
