blazer 4.3 misfire on cly. 6 code p0306
Old Jun 8, 2014 | 06:19 PM
SoullessNihilist's Avatar
SoullessNihilist is on a distinguished road
Default p0306 CYL #6 Misfire
Cyl#6 has bad compression when motor is warm.
Cyl#4 has bad compression when motor is cold.
so maybe the head gasket between these two cylinders is gone. If I leave the plug in cyl#6, cyl#4 gets 120psi. and if I pull it out it only gets 90psi. I don't know how close the in timing the compression strokes are between these cylinders but maybe cylinder#4 dosnt misfire because its using compression from cylinder#6? I'm gonna pull the head in the morning!
Old Jun 9, 2014 | 10:09 AM
ok I pulled the head off and I see nothing wrong with the head, gasket or valves. the cylinder does not look damaged or the top of the piston.
Old Jun 9, 2014 | 10:15 AM
I guess all I can do now is put it back together and hope bad valve seals were my problem. because if the piece of metal I found in the oil pan was in fact a piece of a piston ring it was big enough to have surely destroyed my cylinder wall!
Old Jun 9, 2014 | 12:48 PM
Default P0306 solved
P0306 Solved. the fuel pressure regulator is bad and caused the wash of the top of my lower intake manifold. especially around cylinder#6. the excess fuel in cylinder#6 washed the oil out causing my low compression, misfire and P0306.
unfortunately i'll be installing new head gaskets, manifold gaskets, valve seals..etc. because I found that random piece of metal in my oil pan.
Old Jun 11, 2014 | 11:18 AM
Tranzman's Avatar
Tranzman is on a distinguished road
WOO HOO!!! That was a lot of work, but at least you found the root cause and fixed it. doctors, lawyers and mechanic's are a lot alike... we all practice our trade and hone our skills.
Tranzman
Old Jun 13, 2014 | 10:13 PM
Kurt Kreiger's Avatar
Kurt Kreiger is on a distinguished road
this sounds exactly like my daughters problem in her '05. Misses....coda said valve 6 issue, etc...thanks for the heads up!
TDS-MN
Mar 14, 2014 09:48 AM
berryd8
Nov 10, 2009 02:52 PM
volfan4
Jan 11, 2009 10:57 AM
loppy crimp
Oct 13, 2008 04:17 PM
LittleT
Oct 23, 2007 01:02 PM
