blazer rpm surges
Old Jun 19, 2017 | 05:48 PM
davalex's Avatar
davalex is on a distinguished road
Default blazer rpm surges
have a 99 blazer and more often than not it will surge a few hundred rpm then go back to where it was.does it more with cruise control on but does it without also. sometimes it surges as much as 5 or 6 hundred rpm then drops back to where it was.any help will be appreciated..thanks..Dave
Old Jun 26, 2017 | 04:45 AM
ChuckNTruck's Avatar
This could be caused by quite a few different things.
Throttle vane sticking,
Idle air control valve sticking,
Throttle position sensor issues,
Mass Air Flow sensor issues,
I would suggest trying to rent/borrow a scanner that can read real time data from the above sensors. This way you can see what they are doing when this issue happens.
I am not sure if this will help but I had an issue sort of like this with mine when I bought it. Mine is a 5 speed manual and would rev up between shifts and rev up when put into neutral occasionally but it was very intermittent.
Mine was due to a bad Throttle Position Sensor.
I had to put my scanner on it and read the sensors while I was driving because it was intermittent. My trucks TPS value would usually drop to 0 like it should but sometimes I would let off the throttle to shift and the TPS would hang at 24%. This caused the ECM to think the throttle was open and feed it fuel causing the engine to rev up.
I hope this helps. I am just trying to give you an idea of some stuff to check.
Old Jun 27, 2017 | 05:55 PM
davalex's Avatar
thank you for your sugestions you have been very helpful. Dave..
Naydog101
Nov 14, 2016 09:50 PM
Karen Beech
Oct 2, 2013 12:18 AM
Bonzaibob
Apr 17, 2012 11:11 AM
cutlasskid84
Nov 12, 2007 06:27 AM
oshkosh
Jan 27, 2007 01:22 PM
