Blazer stalling problem
Old Jun 25, 2014 | 06:48 PM
Blazer5501's Avatar
Blazer5501 is on a distinguished road
Default Blazer stalling problem
Ok so I'm new to this and I have been searching the forums but I figured I would jump in here and give my exact problems specific to my situation to get the best results. So I was driving it a month or so ago and it started to act rough upon start up. When I put it in gear it stalled out and would not fire back up. So since then I go to start it up every once in awhile and it still won't turn over, unless, I put it in neutral. Then sometimes dies again once I place it in drive. It is a 95 blazer 4x4 with 180k miles. So if anyone has a clue where to start please let me know.
Old Jun 25, 2014 | 10:44 PM
canuck blazer's Avatar
canuck blazer is on a distinguished road
when was your last tune up? what shape are the plugs wires cap and rotor in? any codes? have you checked the nutural safety switch, and of course are you getting fuel?
Old Jun 26, 2014 | 10:23 AM
Blazer5501's Avatar
Last tune up was about 6 months ago. They aren't in bad shape. No the CEL isn't on. How do I "check the neutral safety switch" also would that affect it dying when I put it in gear? And yeah I'm getting fuel.
Old Jun 26, 2014 | 10:55 PM
neutral safety switch is on the linkage however could also be a vacuum hose to a smoke test will check for that
Old Jun 30, 2014 | 01:13 AM
Blazer5501's Avatar
Has anyone else had this problem? I know it's a 95 but if it were a vacuum leak wouldn't the check engine light come on? I have no check engine lights and now I can start it up. It has no problems at idle, it stays perfect at around 800rpms. I haven't driven it since it stalled and left me stranded when I put it in gear. With no cel could it just need a tune up and fuel filter?
BLAZER92NI
Apr 8, 2012 04:37 AM
beliason
Mar 6, 2012 12:12 PM
sidewheeler
Aug 20, 2009 01:58 PM
Blazer2003
Dec 22, 2008 05:35 AM
Blazer91
Dec 20, 2008 03:36 PM
