-   -   Blazer will not start, I'm at a loss!!! (https://blazerforum.com/forum/engine-transmission-35/blazer-will-not-start-im-loss-63109/)
monkey36 Sep 13, 2011 06:51 PM
My 2000 Blazer was fine until I let it sit for one month. Now it wont start! The fuel gauge always bounced around and I was told this may be a hint that the fuel pump is going. I put extra gas in it, made no difference. So I pulled a plug and there is plenty of spark, I tried starting fluid but I still can't get it to fire. I can hear the pump running but have read that may make no difference, it could still be bad. After reading quite a few posts on here, I decided to buy a new ignition coil, to no prevail however.
The plug wires are relatively new along with dist etc...
I am no master mechanic however have donated a pound of flesh to the back yard mechanic gods, and I'm stumped!!! I am not getting any check engine lights and whatnot. As a side note, the month that it was sitting the battery was dead, I'm not sure if I need to reset something?
So if there is anyone that may be able to point me in the right direction I would be forever grateful!
swartlkk Sep 13, 2011 07:01 PM
You have verified spark, but the statement that it will not run even on starting fluid leads me to believe that either the spark is not properly timed, there is an overly rich condition, or a compression problem any of which might be preventing proper combustion.
Gmas95 Sep 13, 2011 07:11 PM
Go to your local Harbor Frieght and get a fuel pressure gauge usually less then $20. Test the fuel pressure.
Verify, Cranking, Fuel, Spark and Compression. Is the best way to start a No-start issue before buying any parts. Guessing is expensive.
monkey36 Sep 13, 2011 07:14 PM
Well like I had stated, before I parked it, it ran fine. I also put 10 gallons of fresh gas in it and it made no difference. So I'm not sure how the timing would have been thrown off, any other thought or how I might be able to diagnose this?
Gmas95 Sep 13, 2011 07:29 PM
Any signs of small animals? They like to eat wires. Is it cranking fast, does it spudder, or try to fire at all? Try kicking the gas tank, it sometimes will get a failing Fuel pump to get going.
monkey36 Sep 13, 2011 07:50 PM
I've looked everywhere and can see no signs of animal damage. It does not crank any faster than it did before, however when I let off the key from trying to start it, it will cough 1-5 times, like a chugging. I will try hitting the gas tank tomorrow morning and see if that does the trick. As much as I don't want to have to drop the tank and replace the fuel pump I would be ecstatic to have the problem isolated so I can then get it fixed!
swartlkk Sep 13, 2011 07:54 PM
I really doubt that it is a fuel supply problem, but a fuel pressure test would tell the tale in that respect. Given that it won't start with starting fluid, about the only fuel problem I would suspect would be a rich condition. If you had too low of fuel pressure, clogged poppet nozzles, or some other fuel system problem that is preventing fuel from getting to the cylinders, adding starter fluid into the throttle body should allow it to start.
One thing worth mentioning... When you are trying to start it, is the intake duct work intact from the filter box to the throttle body? If not, is it intact from the MAF sensor to the throttle body? If the MAF sensor electrical connection is plugged in, but the air entering the engine is not all being pulled through the MAF sensor, it can cause starting problems.
monkey36 Sep 13, 2011 07:59 PM
So if it were a rich condition, what would be my next best option? Pull the spark plugs and take a look at them? Them what should I do to rectify the problem?
Gmas95 Sep 13, 2011 08:16 PM
So right now it is basically cranking over, not firing at all and even when you spray starter fluid it does not fire or attempt to fire. When you turn the key off it sputters like it is chugging? Is it dieseling? And you are positve you have spark?
monkey36 Sep 13, 2011 08:19 PM
It is doing a little bit of chugging when I let off the ignition key, but not run on (dieseling)
I pulled one of the plug wires and had a plug in it and turned it over and there was plenty of spark.
All other points you recapped are correct. Do you have an inclination as to what it may be?
