Blazer will not start, I'm at a loss!!!
Old Sep 13, 2011 | 08:27 PM
Gmas95's Avatar
Gmas95 is on a distinguished road
Can be lots of things unfortunately , Try checking spark from all 6 wires, Can just pull one plug then hook it to each wire.
Check to see if the plug smells like gas also, is wet or has black soot on it.
Old Sep 13, 2011 | 08:32 PM
monkey36's Avatar
monkey36 is on a distinguished road
Ok, I will try that tomorrow along with kicking the gas tank and trying to rent a gauge to read my fuel pressure. I will let you all know how it works out.
Old Sep 13, 2011 | 08:56 PM
Gmas95's Avatar
Make sure you slightly kick it, dont got doing any more damage
Old Sep 14, 2011 | 11:01 AM
monkey36's Avatar
This sounds exactly like my issue, could this be my problem?
https://blazerforum.com/forum/2nd-ge...o-start-28385/
Ok guys, she's alive again. As you'll see in my previous post after searching last night for hours!!!! I found someone with the exact same symptoms and issues I was having!
So rather then trying anything else I replaced the dist cap and rotor, I barely turned the key and she fired right up!!!
Thank you everyone for all of your input!!!!
Last edited by swartlkk; Sep 14, 2011 at 12:48 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Sep 14, 2011 | 01:05 PM
Glad you got it fixed!
Old Sep 14, 2011 | 11:46 PM
moon's Avatar
moon is on a distinguished road
try checking voltage at the coil while cranking engine to see if its dropping out just had a honda that was doing same thing was a bad switch found it accidentally was letting off switch an it started up then died.
bryanmine
May 19, 2011 11:27 AM
stschuyler25
Nov 21, 2010 09:34 AM
chiajake
Apr 2, 2008 11:21 AM
ndekens
Nov 14, 2007 09:47 PM
