blazer wont start
Old Dec 25, 2007 | 01:59 PM
Asimm's Avatar
Asimm is an unknown quantity at this point
Default blazer wont start
Ok my blazer has been sitting out side and wont start it started earlier today but when i went to go restart it wouldnt... the battery has not been used in over 3 inths and has been outside.. and i didnt let it run for a long time during th first start up... is it becouse the battery is completly dead... but all the accesories work it wont even crank when i turn it to the start...
Old Dec 25, 2007 | 02:39 PM
Default RE: blazer wont start
Have you tried to jump start it? I would remove the battery connections and make sure that they are clean.
Old Dec 25, 2007 | 04:13 PM
Asimm's Avatar
we tried to jump start it took a while the first time to start but wouldnt start the second time so we tried to jump start it again it then proceded to not make a noise when you turned it to start but all the electronics worked. we thought we blew a fuse but we checked all of them and there was problem there.. but i just went out to see if it would make a noise when you try to start it and it made a little faint noise like the electricity was tring to start it but there wasnt enough power... hopefully i can just get a new battery and that will be it.
Old Dec 27, 2007 | 03:56 PM
Hanr3's Avatar
take the battery to your parts store and have them test it.
Check your battery cable to the starter and the starter connections too.
dj00140
May 20, 2013 06:37 PM
JimmyBlaze541
May 2, 2013 10:00 AM
bobby099
15
Nov 7, 2012 07:29 PM
FreeTime
Sep 8, 2012 01:38 AM
jetsmy
Aug 1, 2008 10:10 PM
