Blazer zr2 2000 4.3L pipe (check pic!)
8 Attachment(s)
Is this could cause problems later? check the pic.
When I open it was stuck and it squeezed this pipe a bit when it start comeing open, when I notice that it start twist a pipe I play open-closea bit and then it was comeing loose. If it is then I need to order new one. One end is attached to engine and ohter end goes to exhaust manifold. |
That is the EGR supply tube, it needs a new one ;)
Originally Posted by Captain Hook
(Post 649584)
10/4 I placed the order :) tnx |
2 Attachment(s)
Originally Posted by weix2
(Post 649617)
10/4
Not fun, but you'll get it in. Antiseize on the threads will help the next guy.... it might be you ;)
