blown rod??
Old Mar 22, 2008 | 07:49 PM
Asimm's Avatar
Asimm is an unknown quantity at this point
Default blown rod??
ok so i have 1993 s10 blazer 4*4 and with a 4.3L vortec. today i was driving it and it felt like it had no power. a bit later i went and got onto the higway and i nearly had to floor it to watch my speeddometer snail its way up to 70. then after about a quik 3 min i started to hear a really lound knocking noise when i pressed the gas. i pulled of at the next exit and checked the oil etc. the oil was smoking and later when my step dad came up (he used to rebuild and teardown allot of engines before) he said that it is a blown rod..
any suggestions or help would be great! I will be glad to answer any questions if you have any.
Old Mar 22, 2008 | 09:52 PM
Dturner14's Avatar
Dturner14 is an unknown quantity at this point
Default RE: blown rod??
Normally if I had that problem lke with an old car I had I would say get a new enigine.
Old Mar 22, 2008 | 10:37 PM
4x4blazerguy's Avatar
I agree just get another engine. Check out the wrecking yard. Not worth rebuilding IMHO.
Old Mar 23, 2008 | 06:40 AM
Asimm's Avatar
well since im not very um car-smart what exactly do i have to know to get a new engine that fits my blazer?
Old Mar 23, 2008 | 05:18 PM
If you have the CPI motor, another CPI motor is what you need. Your step dad is mostlikely correct. Sounds like you spun a rod bearing, most likely trashing the crank in the process. A used motor is the cheapest route to getting your vehicle back on the road.
Old Mar 23, 2008 | 05:23 PM
972DRBLAZER's Avatar
972DRBLAZER is an unknown quantity at this point
sounds like it is time for a 350 swap.
Old Mar 23, 2008 | 07:50 PM
Asimm's Avatar
ha i like the 350 idea but how do you get the info to know if its a cpi or not?
Old Mar 23, 2008 | 08:12 PM
i think in 93, it had tbi. but not sure. just look at your fuel injection setup.
Old Mar 23, 2008 | 08:18 PM
Asimm's Avatar
well, whats the difference im more of a computer wiz than a mechanic sorry
Old Mar 23, 2008 | 08:48 PM
any local shop can tell you what exactly what you need, but allways get a second opion, just because there are alot of shadey mechanics out there trying to make the easy money.
