bog down, loss of power when AC turned on
Old Aug 8, 2010 | 08:56 AM
dm911's Avatar
dm911 is on a distinguished road
Question 1990 2.8L, 2/wd - dramatic loss of power when AC turned on
Hi guys,
First post but find very infomative. I have a 1990 S-10 Blazer, 6 cyl, 2.8L, 2WD. When I turn the AC on the engine really seems to struggle with a rough idle and noticeable loss of power with a corresponding drop in oil pressure via the guage (not mechanical). The AC does work and I know the compressor will draw quite a bit of power on such a small engine but is this maybe a sign that the compressor is going out and what can I do to troubleshoot? Thanks in advance.
Last edited by dm911; Aug 8, 2010 at 10:16 AM. Reason: Wanted title to have model of blazer
Old Aug 8, 2010 | 01:38 PM
dm911's Avatar
Unhappy OK - no thoughts?
OK - as no replies, then this must be a lousy question or obvious to everyone. Thanks.
Old Aug 8, 2010 | 01:53 PM
TripleBlackBlazer's Avatar
Originally Posted by BlazerForum Rules
4.
Double posting is not allowed and can result in the deletion of one or both posts. Double posting is defined as posting the same information in two or more separate forums. We understand that some topics might fit into more than one forum. Please try to pick the best one. In addition, please do not post in the same thread back to back (another version of double posting), if you have something more to add and another member has yet to respond, please edit your thread. If, after waiting at least 24 hours, someone has not responded, you may "bump" your thread back to the top. In doing so, it is probably best to leave out any sarcasm or witty remarks. After all, you are the one requesting help... Best to do so in a polite manner.
Please be patient. It is the weekend and not everyone gets to the computer as often as others.
Old Aug 8, 2010 | 02:37 PM
+2 to what TBB said.. You barely waited 5 hours...
Now, about your problem.. You mention power loss. Does having the A/C on affect power as you accelerate or while cruising along? If it does, you could have some fairly significant health issues with your engine that have sapped enough power to make the power draw by the a/c system more noticeable.
If the concern is mostly at idle only, then you may have a problem with the IAC (idle air control) valve that is supposed to maintain idle speed by adjusting the amount of air that gets fed to the engine. You could try cleaning the IAC valve. It bolts into the side of the throttle body.
If you haven't already done a tune up (plugs, wires, cap, & rotor at a minimum), I would do so now as well.
Old Aug 8, 2010 | 02:44 PM
dm911's Avatar
Thank you guys. Sorry for the impatience. Will do better from now on.
In regrards your comment, yes it seems to be more evident at low rpm's to idle. For an old 2.8 putt putt it still has a bit of spunk once rpm's up to >1500 with ac on or off (better off but too hot for much of that right now!!!!).
I'll check and clean the IAC first and go from there. Tune-up to come Monday. I will comment back on results. Again thanks and apologizes.
bryanmine
May 19, 2011 11:27 AM
bertrenolds
13
Jan 17, 2011 12:11 PM
Freakshow
Jan 13, 2010 04:41 PM
Don1188
Nov 8, 2009 11:27 AM
willysboy2001
Jul 23, 2009 10:21 AM
