Boggled!
Old Aug 24, 2011 | 12:05 PM
CRESTBOMBER's Avatar
CRESTBOMBER is on a distinguished road
Question Boggled!
88 V-10 Blazer 5.7 engine runs poorly, idles irraticly and dies out when new MAP sensor is plugged in. Unplug MAP vaccum or electrical plug and it runs at least. I have replaced oxygen sensor, EGR valve, temp sensor, thermostat, MAP sensor, distributor module, plugs, wires, cap, rotor. Replaced most sensors except knock and ESC. No codes since replaced MAP sensor and erased MAP code. Still runs poor when engine loaded in gear. Revs up in park. Cylinders all have 125 lbs of compression and replaced throttle body gasket. What's next?
Last edited by CRESTBOMBER; Aug 24, 2011 at 12:07 PM. Reason: Forgot Make and model
Old Aug 24, 2011 | 12:27 PM
pettyfog's Avatar
Back to basics
Check timing, look for erratic timing.. if it is erratic, check distributor mechanics.
Check tailpipe for individual exhaust puff.. trouble being it's hard if you dont know what normal is.. amazing the people who dont!
Check plugs.. any too rich or too lean?
Old Aug 24, 2011 | 06:24 PM
AJBert's Avatar
Can I see a pic of your 5.7 V-10???
Sorry, I couldn't resist.
