broken starter bolts
Old Feb 28, 2014 | 04:15 PM
mr.vls's Avatar
Have you tried a close quarter drill for access?
3/8" Close Quarters Drill
Old Mar 2, 2014 | 04:02 PM
berniescout's Avatar
berniescout is an unknown quantity at this point
2nd bolt out. long extention did the trick. must have a dull left hand colbalt bit. went in w a right hand hss 1/4" bit and it cut like butter. then used the left hand to back it out. going to be a cold week so may wait to put new starter in. thankfully we have missed the snow this time.
bernie
Old Mar 4, 2014 | 03:15 PM
yea!!!!
new starter in!!!!
to anyone else in the broken bolt situation heed the following advice. use some sort of extension or a long drill bit. I worked w both a spade bit extender and a bolt in a spare drill chuck to reach up to the block to drill out the broken bolts. Use a new bit - good quality.
I drilled with the right hand bit and walked out the broken bolts w the left hand bits. somehow the snap on left hand bits are cut(machined at the wrong angle vs the hss bits)
now on to the rear brakes (parking) and an inspection.
thanks to all that posted on this thread and good luck to the future readers.
finally, if you find one bolt broken, deal with it asap.
bernie
schrack
Mar 13, 2015 08:42 AM
jdmmario
Oct 25, 2014 06:25 PM
drummerdude
Nov 13, 2009 09:11 PM
brunosrk
Jan 20, 2008 09:13 PM
mtncrsr
Jul 12, 2006 06:44 PM
