camshaft position sensor help
Old Sep 28, 2010 | 04:24 PM
TheNewKid's Avatar
TheNewKid is on a distinguished road
Question camshaft position sensor help
ok so new motor (93 vortec 4.3) i got does not have a crank sensor on it old one does (96 vortec 4.3) is there a way to bypass or do i have to have that sensor or what do i need to do???????
Old Sep 28, 2010 | 07:06 PM
You cannot bypass the CKP sensor. Your only hope is that you can swap the timing cover and reluctor ring (on the crankshaft) from the old motor onto the '93...
You really should have found another '96+ engine to use. That would have been a pain free swap and included the better heads/cam of the SCFI engine...
Old Sep 29, 2010 | 08:38 PM
TheNewKid's Avatar
got brand new heads for a 96 with compcams roller rockers and lifters also have a high dollar comp cam that came with the engine block is 93 ish but has all the 96 and up heads and stuff just not the ckp
russ1609
Jan 30, 2012 07:08 PM
bulletuga
Jul 26, 2010 08:26 PM
rob2129us
Dec 19, 2007 10:03 AM
murfthesurf4
Nov 26, 2007 11:00 AM
88blackzcand95blazer
Jan 26, 2007 04:36 PM
