camshaft's
Old Dec 30, 2008 | 05:22 PM
bamablazer57's Avatar
bamablazer57 is an unknown quantity at this point
Default camshaft's
hey all im just wondering if anyone knows where i can get a aftermarket cam for a 2001 4.3 vortek v6. thnks all.
Old Dec 30, 2008 | 07:03 PM
Default RE: camshafts
Many different manufacturers make aftermarket cams for the 4.3L engine. Comp Cams and Crane both have a selection of varying profiles. Each profile has its pros and cons which will need to be weighed before a certain grind is selected. I would start by browsing through sites like SummitRacing.com, Jegs.com, and a few other similar sites for options. You should get a good picture of what manufacturers make cams for this engine. From there, you will need to look at the specifics of each grind and what the pros/cons are. I know that Comp Cams has a very good tech line as I have called it a few times for advice, last time being a few years ago... Do not be afraid to contact the manufacturer and ask questions on the benefits (power, torque, mileage, etc) and likely downsides (idle quality, vacuum strength, etc) of each grind that you are researching. The cam is the heart of the engine. Sometimes without other supporting mods (exhaust, head work, etc), the full potential of a cam cannot be realized.
Bybsurfr32
Jun 2, 2019 04:00 AM
Navy85
Feb 24, 2008 08:12 PM
rob2129us
Dec 19, 2007 10:03 AM
murfthesurf4
Nov 26, 2007 11:00 AM
88blackzcand95blazer
Jan 26, 2007 04:36 PM
