Can the goodyear gator back belt cause a wining noise
Old Jun 15, 2009 | 01:19 PM
cr8390's Avatar
cr8390 is an unknown quantity at this point
Originally Posted by W2JGA
Take the belt off and start it.
Pretty sure thats not a good idea dont do that
I just put a gatorback on my truck a month ago before i went from north carlina to new york and back and ive had no problems and no noises
Old Jun 15, 2009 | 08:08 PM
AJBert's Avatar
Try revving the engine in park and see if the noise is there before buying another belt. If the noise isn't there it is something else.
Old Jun 16, 2009 | 03:20 AM
W2JGA's Avatar
W2JGA is an unknown quantity at this point
Why is that not a good idea? He only needs to run it long enough to determine if the noise is indeed belt, or pulley related. We do it all the time in the auto industry with no negative results.
Old Jun 16, 2009 | 12:15 PM
ExplicitYourSelf's Avatar
ExplicitYourSelf is on a distinguished road
so if i choose to remove the belt how far/how much time can the car be driven for?? So doing this will not damagemy motor/battery??
Old Jun 16, 2009 | 05:41 PM
I revved it today and the noise was there... I called kregan auto parts to check the warrenty on the belt and it had a 3 month warrenty, and i purchased it on Jan 6 2009
Old Jun 16, 2009 | 09:19 PM
I would not drive the vehicle with the belt off. Since you hear the noise while rev'ing the engine in park, then the noise is RPM dependent.
I would remove the belt and check over all pulleys for play and/or gritty feeling. Then start the engine and see if the noise is still present when you rev it. You can safely run a cold motor for a minute or two without a problem.
After you reinstall the belt, check the tension. You should not have more than a 1/2" of deflection in the belt in the longest stretch between pulleys if it is tensioned properly.
Rust_bucket
Aug 23, 2014 03:00 PM
ComputerNerdBD
Apr 2, 2013 08:12 PM
LRV31
Oct 25, 2011 04:47 PM
ded2klf
Nov 29, 2010 10:15 PM
jus1087
Nov 11, 2007 02:03 AM
