cant figure out engine total loss of power at any rpm
Old Oct 20, 2013 | 01:17 PM
Empire932's Avatar
Empire932 is on a distinguished road
Default cant figure out engine total loss of power at any rpm
VEHICLE: 1996 s-10 blazer
THE ISSUE: at any rpm above idle, it wants to misfire, BAD, to the point its hard to get the rpms any higher once its started to act up(usually around 1500rp).
Idles fine.
If i try to get the rpms higher(usually flooring it) as soon as i let off the gas, as the rpms go down its smooth, so i can go to 3k and it will return to idle without a problem. This is all in park. No load
It first started all at freeway speed, out of nowhere causing me to pullover and limp home at idle.
THINGS IVE TRIED/new parts:
I have another blazer(running condition) same year so i swapped some parts:
Pcm
Coil
Maf
New parts:
Distributer and all ignition parts(less than a month)
Fuel pump(about 2 years)
Fuel pressure is about 58 at idle, goes to 62ish when trying to raise rpms
I know thats slightly below standerd, but not sure if thats enough to cause the problem
Any and all help is appreciated
Thanks
Old Nov 11, 2013 | 01:52 PM
Home1art's Avatar
Home1art is on a distinguished road
Try check catalytic converter. If you have oxygen sensor before cat take it out and make sure to deflect exhaust gases with something metal if pointed toward items that can burn or melt. If RPM goes up to say 4000-4500 fast then you clogged cat. Note CEL will probably light up you will need clear it when done with test.
Old Nov 11, 2013 | 04:35 PM
dirt101's Avatar
dirt101 is on a distinguished road
exactly what I was thinking as well. clogged cat!
matthewp
Jun 9, 2020 01:54 AM
repairme
Jul 24, 2011 02:28 PM
pbaxter87
Jun 17, 2010 01:53 AM
butters
Oct 6, 2009 06:14 PM
slow01ss
Feb 25, 2009 03:52 PM
