cant figure out which starter i need
Old Nov 24, 2012 | 09:11 AM
brino1's Avatar
brino1 is on a distinguished road
Default cant figure out which starter i need
I've got a 96 4.3 and a 153 tooth flywheel.Ive tried 3 different starters and none of them worked.does anybody know what starter I need?
Old Nov 24, 2012 | 01:24 PM
neo71665's Avatar
Are you shimming them or just bolting them straight to the block?
What exactly is the problem with the 3?
Old Nov 24, 2012 | 03:39 PM
richphotos's Avatar
I did not have to shim my starter when I put it in the jimmy last weekend.
What Neo said, what is it doing, or not doing?
Old Nov 24, 2012 | 11:39 PM
neo71665's Avatar
I've had to shim them on one starter then remove the shims when I replaced the starter. Just depends on the starter but 90% of the time they do need some shim or they will bump the flywheel/flexplate and not engage the teeth. Also seen them hang and not disengage.
Old Nov 25, 2012 | 10:52 AM
richphotos's Avatar
I must have gotten lucky than, Even the old starter was not shimmed.
Old Nov 25, 2012 | 03:20 PM
brino1's Avatar
The starters were way off.it used to have an automatic trans and I went to a manual
Old Nov 25, 2012 | 03:52 PM
Joshs4x4's Avatar
Joshs4x4 is on a distinguished road
Starters no longer need to be shimmed
Old Nov 25, 2012 | 04:07 PM
neo71665's Avatar
I've got all kinds of trucks in my yard that still use shims. From a 64 with a 292 i6 to a 98 4.3 s-series. Just got done putting a starter on a 96 2500 with a 350 and it didn't have shims but we had to add them. Maybe on the new ls engines they don't need shims but any gen 1 based sbc design or older 6 and 4s might need them.
What do I know I only work in/run a mechanic shop.
Old Nov 25, 2012 | 04:42 PM
richphotos's Avatar
LOL neo, No doubt they need shims, sometimes you just get lucky and dont need to put any in.
Old Nov 26, 2012 | 05:59 AM
brino1's Avatar
The issue I'm having isn't a shim issue.I guess GM used a bunch of different starters.I think I found what I need.its expensive though
