Can't get driveshaft out.
Old Apr 11, 2009 | 06:17 PM
Beauhawk's Avatar
Beauhawk is on a distinguished road
Default Can't get driveshaft out.
Can't seem to remove the rear driveshaft on my 99 4wd. i have the 4 bolts and 2 bands off, but it's not budging. Any ideas?
Old Apr 11, 2009 | 06:20 PM
oisinirish's Avatar
I had to beat on mine "carefully" when I changed the U-Joints on my '05 Silverado. She sees mud almost daily and has almost 120,000 miles so condition might be similar to yours...LOL.
The drive shaft isn't in a bind against the gears is it?
Old Apr 11, 2009 | 06:28 PM
Beauhawk's Avatar
No, I don't think so. The jackstands are currently under the axle. Are they supposed to be on the frame (unloaded suspension).
Old Apr 11, 2009 | 07:53 PM
You do not have to unload the suspension. Quite often the cups on the u-joint stick in the yoke on the front of the differential.
When I replaced the u-joints on my old 2000 Bravada, I had to put my long pry bar between the differential yoke and the u-joint, then smack it with a hammer to jar it loose.
gitch93
Jan 23, 2013 04:51 PM
mudcat
20
May 4, 2011 05:47 AM
giaco
Apr 4, 2010 05:03 PM
90K5Blazer
Oct 7, 2009 10:01 PM
pigmak
Nov 26, 2006 06:02 PM
