cant get it to stsrt
Old 10-09-2013 | 11:25 AM
jatkins3983's Avatar
jatkins3983 is on a distinguished road
Default cant get it to stsrt
I just can't get my blazer to start it was working fine this morning and how it won't crank. Ive replaced the starter and battery about 3 months ago yesterday the sparkplugs the distributor cap, rotator button and the spark plug wires and now she won't turn over. I can hear the fuel pump whirring but I'm thinking it may not be getting gas could it be the fuel filter
Old 10-09-2013 | 11:29 AM
I know I need to replace the fuel pump assembly because it doesn't read the right amount of gas but it pumps well I just don't know really what it is . Anny suggestions y'all thanks 1999 Chevy blazer LS with a 4.3
Old 10-09-2013 | 11:59 AM
rexmburns's Avatar
Super Moderator
Do a double check of everything that was replaced yesterday! If it was fine before replacing them and its not now %99 its one of those things. The wires could be wrong causing it to fire out of order, the cap could be on backwards or loose who knows but check the things you listed and see if that fixes the problem.
Old 10-09-2013 | 12:52 PM
I also got 1993 s-10 blazer tahoe lt and the brakes won't work replaced the brake light switch and bulbs and still no brakes any ideas. And I will recheck the others on it
Old 10-09-2013 | 01:10 PM
rexmburns's Avatar
Super Moderator
You should have this in a seperate thread so your don't have to issues on two vehicles going in the same thread. It would get really confusing really quickly!!
What is is about your brakes that don't work?
Old 10-09-2013 | 05:22 PM
Well that's it they just don't work when pressed the flashers work the hazard switch works. But the brakes just don't do anything. I've replaced the bulbs the brake light switch and no joy
Old 10-09-2013 | 05:33 PM
toyhauler1283's Avatar
toyhauler1283 is on a distinguished road
I know this will only help the confusion of this thread but... when you say no brakes you mean you push the pedal and the car won't stop moving? Or when you push the brake pedal you have no brake lights? 2 completely different problems
Old 10-09-2013 | 05:35 PM
rexmburns's Avatar
Super Moderator
^^^x2^^^.
Old 10-09-2013 | 05:48 PM
How do I start a new thread? Brand new here. And it stops excellently well but no lights
Old 10-09-2013 | 09:04 PM
rexmburns's Avatar
Super Moderator
Same way you started this thread and all of the rest of the threads you have made! go to the appropriate section and click 'new thread' in the upper left hand corner
For the lights the best place to start would he with a multi meter at the tailghts and see if your getting power and ground back there then work your way forward. The neutral safety switch may be having something to do with it also.
Quick Reply: cant get it to stsrt
