Cant move Air intake cover
Old Nov 5, 2011 | 08:01 PM
kuojo's Avatar
kuojo is on a distinguished road
Default Cant move Air intake cover
Ok so trying to replace the camshaft sensor on the distributor, I have to remove the air intake on top of the engine block, I think its called the phyelm air intake or something, to actually get to the distributor. One problem- I just can't seem to get the thing to budge. I undid all the bolts, took off the sensor, and tried to release the seal by pulling a vacuum hose, and nothing has even affected it. It feel like its being held in place. Has anyone else had this issue or am I just missing something important? Can anyone help? I can try and provide pics but my camera doesn't like to work all that much. Thanks guys
Old Nov 5, 2011 | 08:16 PM
warthogdriver's Avatar
this will cover more then you need but will show you how to take top end apart.
http://www.handymanliness.com/archiv..._99_Jimmy.html
hope that helps.
Old Nov 6, 2011 | 06:23 PM
kuojo's Avatar
Thanks! I was able to get it off the engine and take apart most the distributor. Now I have another question (sorry if these questions seem very obvious, I just learning how to do this): How do I get the distributor off? According to the chiltons manual I should just be able to loosen the clamp bolt and it comes right up but I have no idea how to loosen the bolt. I can't fit a wrench or a rachet in the small space so is there something I need to move? Something else I have to do before I can lift the distributor out? I will post pics as soon as possible.
Here are some pictures with what I am dealing with. Am I missing a step or do I need to move something? I have no idea what to do. Please help
Attached Thumbnails Cant move Air intake cover-distributor-bolt-.jpg   Cant move Air intake cover-rachet-bolt.jpg   Cant move Air intake cover-wrench-bolt.jpg
Last edited by swartlkk; Nov 6, 2011 at 08:29 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Nov 6, 2011 | 07:30 PM
Little Roober's Avatar
Little Roober is on a distinguished road
I used a short 10 mm wrench. Once it was broken loose I could use my fingers the rest of the way.
Old Nov 6, 2011 | 07:55 PM
make sure you mark it!!!
or you will mess up your timing
Old Nov 6, 2011 | 07:58 PM
kuojo's Avatar
Its all marked and ready to go. Whoever has done work on this engine before used a 9\16 bolt instead of a 10mm and everything is to long to fit in the small space. I just tried with a 10mm
Old Nov 6, 2011 | 08:21 PM
try a socket and universal joint with a long extension?
Old Nov 6, 2011 | 08:31 PM
Crows foot socket! Makes quick work of close clearance fasteners like that!
Old Nov 6, 2011 | 08:35 PM
chris015's Avatar
They make wrenches for distributors....its the easy way and cheap.
Old Nov 6, 2011 | 08:49 PM
kuojo's Avatar
Ok.. I am gonna buy a set of crows feet sockets and a distributor wrench. Both will probably make my life easier. I will keep posted on how trying to get this bolt to loosen goes.
Stuck In Muddy Mo
Nitrous, Super Chargers, & Turbos
Jan 27, 2014 02:32 AM
ComputerNerdBD
Headers, Intake, & Exhaust
Jan 5, 2012 04:53 PM
dimmuborgir6nik6
Oct 2, 2008 06:51 AM
frankjc
Aug 7, 2006 11:12 AM
