carb ?
Old Jul 18, 2007 | 11:25 AM
jims3000's Avatar
jims3000 is an unknown quantity at this point
Default carb ?
i have 1984 2.8l engine with carb problems it is a 2se and i can get a carb off of a 79 4.3l engine and it is a holley 2se would this bolt right up and run fine?
Old Jul 18, 2007 | 11:50 AM
Default RE: carb ?
hmm... You could give it a shot, but I doubt they'll both have the same linkages... It may bolt up...
You could rebuild the carb you have... Here's some info on it:
Carburetor Factory - Rochester 2SE Exploded View
No correlation from exploded view # to actual description...
The Unofficial Guide to the Rochester Varajet 2SE/E2SE Carburetor
This one has a ton of very disorganized information...
There is also a manual available on the proper tuning and overhaul of this carb. Autozone has some information on their site as well.
Brandon Smith
Dec 22, 2013 12:33 PM
boomtruck97
Engine & Internal
Jun 29, 2006 02:45 PM
Manley_pm
Dec 19, 2005 11:18 PM
jotajota
Engine & Internal
Dec 11, 2005 11:45 AM
zero psi
Engine & Internal
Dec 11, 2005 12:20 AM
