change from a 4 to a 5 speed tranny
Old Jan 27, 2009 | 11:51 AM
Sunshine Coaster's Avatar
Sunshine Coaster is an unknown quantity at this point
Default change from a 4 to a 5 speed tranny
Hi all....quick question, my '86 Blazer 4x4 with a 2.8 has a 4 speed man. tranny. I do mostly highway driving at 80+ kmh and was wondering if I found a replacement 5 speedwould the gear ratio be different enough to lower my RPMs and increase my mileage? What I'm asking is, does anyone know the final ratio of a 4 speed vs. the 5 speed that would bolt-in for this year? Thanks in advance for the help.
Old Jan 27, 2009 | 12:49 PM
Default RE: change from a 4 to a 5 speed tranny
It really depends on what the ratios in your current trans are and what they would be in the replacement trans. If you have the stock 4 speed should be a Borg Warner T4 with gear ratios of 1 - 4.03, 2 - 2.37, 3 - 1.50, 4 - 1.00, R - 3.76. The most popular swap would be to go to the Borg Warner T5 which just adds a 5th gear at a 0.86 ratio for an overdrive gear. I believe the cases are the exact same length and should be a direct swap.
Pipewrench Dale
Nov 10, 2014 06:16 PM
jdub9000
Jul 22, 2013 07:58 AM
Hormisdas
Nov 27, 2012 09:42 PM
jdpilot
Nov 12, 2008 06:01 PM
