Changing Oil Type
Old Feb 22, 2009 | 06:08 PM
BlazinMike89's Avatar
BlazinMike89 is an unknown quantity at this point
Default Changing Oil Type
Ive Read alot of other posts about Seafoam and Synthetic Oil So heres my Question, I Beleive I have a slight Intake Manifold Exterior leak, i can see a lil bit of it. My Oil levels are fine my antifreeze gets a little dirty and i top it up but other than that its fine, Now I Want to seafoam my Intake and Possibly my Crankcase as well. My Truck has 126,558 miles on it. Had Everything Tuned up in April 08. I want to seafoam it and the switch to amsoil 10w-30 Synthtic Oil. If I seafoam it will it cause more damage and secondly can i switch to syn next oil change?
Old Feb 22, 2009 | 06:55 PM
rriddle3's Avatar
Default RE: Changing Oil Type
I would get the intake manifiold gasket replaced prior to doing the Seafoam and, yes, you can switch to syn oil after it's all done.
Old Feb 22, 2009 | 07:03 PM
Any Chance it will leak more and worse if i seafoam before I change the gasket?
Old Feb 22, 2009 | 07:13 PM
rriddle3's Avatar
I would say it is possible. Who knows?
Old Feb 22, 2009 | 07:20 PM
i see, well ill tackle that when the weather gets warmer, ill do a seafoam treatment a couple of times to clean all the crap out then flush the Heater Core And Radiator and change the Manifold and Head Gaskets
Old Feb 22, 2009 | 09:15 PM
WolfPack's Avatar
I mix a little seafoam in with my cereal in the morning
Old Feb 23, 2009 | 12:06 AM
AJBert's Avatar
[sm=funnypostabove.gif]
Old Feb 23, 2009 | 01:05 AM
Cavalier z24's Avatar
Cavalier z24 is on a distinguished road
just replace the intake gasket first to be safe
Old Feb 23, 2009 | 01:26 AM
bandidolenny's Avatar
I run mobil1 10w-30 in my 98 4.3 blazer... I change the oil every 10k and the filter every 5k. Swapped it over to synthetics at 90K miles and now at 120k... so far no leaks.
96jimmyslt4x4
Jul 18, 2011 10:08 PM
davidsv8mustang
Dec 8, 2010 10:23 AM
MagnumRulzes
Feb 25, 2009 05:13 PM
Blazer4U
Aug 30, 2008 11:31 PM
Drifter666
May 9, 2008 10:14 AM
