Changing old tranny fluid...
Old Jun 3, 2009 | 05:14 PM
HHimmy's Avatar
HHimmy is on a distinguished road
Default Changing old tranny fluid...
I need to solve a long standing issue with trannies. Is it best to leave old burnt fluid in a trans, or flush it and change it out? I have been told by transmission guys that at some point, there is no turning back when the fluid is too bad: changing it would remove whatever is keeping plates and such together. Is this just b.s., or is there some truth to the matter?
Old Jun 4, 2009 | 03:47 PM
Denominator's Avatar
Denominator is on a distinguished road
Can't say for sure. But on my Ford F150 1986, it was like day and night, from very old fluid to new fluid. I did have to change it a few times, but after about 3 changes, the transmission felt like new. This is a transmission that have been along for 372.822 miles (600.000 km), and stil is going amazingly strong!
Old Jun 5, 2009 | 07:06 AM
billymac49's Avatar
billymac49 is on a distinguished road
there is some truth to that. changing the can lead you to a rebuild quicker than you want. the new fluid acts like a detergent to the frictions cleaning the linings. either way if the fluid is that dark and smells burnt it is just a matter of time when the rebuild happens. i work in a tranny shop and we get customers asking that same question all the time. if it is working good you may want to keep using it, just be aware of what is around the corner!
Old Jun 5, 2009 | 07:23 AM
Where much of the stigma comes from is transmission flushes. Flushing a high mileage transmission with an ultrasonic flush machine can definitely loosen up areas of sediment that has accumulated near seals, etc. This sediment can help those seals in their sealing duties, but it also can eat away at the seals in the process. Clean it out and the seal may now leak.
It is by far best to drain the pan and top off the fluid as part of routine maintenance.
Old Jun 5, 2009 | 05:56 PM
HHimmy's Avatar
Thank you, sir
BrinkDiamond
Mar 2, 2014 03:50 PM
ski.dive
Feb 7, 2014 05:18 AM
mikepro
Aug 15, 2011 07:03 PM
kwikshifter
Jul 16, 2010 01:35 AM
AutomagicLS1
Engine & Internal
Dec 1, 2006 11:08 PM
