Chevy Blazer 98, Stalling, hesistating. MAP sensor replaced, code call for bad MAP
Old Mar 12, 2018 | 05:21 PM
Mar tko's Avatar
Mar tko is on a distinguished road
Default Chevy Blazer 98, Stalling, hesistating. MAP sensor replaced, code call for bad MAP
Long topic but basically describe it all.
Blazer 98. 4.3L
It was not used for a long time(3 years) , and finally revived it.
Done a full tune up, replaced all fluid and replaced spider injector.
Vehicle worked fine for about 5 months and all the sudden had a hard time to start it, it was stalling and hesitating, but finally kicked off.
Ended up dying whilst I was going up the bridge 30 min into driving. Was able to start it and idle it back.
Now the problems that are quite consistent are.
Stalling, hesitating, dying when gas pushed quickly, but when pushed slowly I can floor it.
When it is about to die, it kicks in automatically high idle for a moment to maintain vehicle going, then eases down to normal, once i press quickly, starts dying.
Code was shooting for bad MAP sensor, after replacing.... The same problems, and code.... bad MAP sensor.
I looked for vacuum leak, sprayed around with starting fluid to see it vehicle revs up, but couldn't find anything.
I noticed that my PCV is really filthy but still rattling, replaced it, didn't improve anything.
Now I'm thinking about fuel pump but it was replaced 5 years ago, and getting fuel.
Old Mar 14, 2018 | 07:38 AM
LesMyer's Avatar
Sounds like fuel pump or plugged fuel filter or some other fuel supply related issue - test with fuel pressure gauge connected to Schrader valve per sticky at top of 2nd gen forum (regulated to 58 psi with KOEO is OK for replacement MPFI spiders). Most parts stores have free loaner fuel pressure gauges.
Old Mar 14, 2018 | 01:41 PM
rockp2's Avatar
What is the code and is it the only one?
blazen_red_4x4
14
Jul 2, 2014 07:48 PM
optimus485
May 12, 2012 07:07 PM
cage47
Apr 9, 2010 01:15 PM
Sunshine Coaster
Oct 20, 2007 12:24 AM
RCars2
Jul 6, 2007 10:57 PM
