Ls swap with a 4 wheel drive
Old Mar 10, 2018 | 05:05 PM
Randywolf244's Avatar
Randywolf244 is on a distinguished road
Default Ls swap with a 4 wheel drive
I wanting to do an ls swap with my 4 wheel drive truck but the only kit I can find is a 2 wheel drive kit. Obviously I won't be able to make it 4 wheel drive but am I able to use this kit as it is or do I need to look for another one? I don't care if I lose 4 wheel drive
Old Mar 14, 2018 | 07:57 AM
LesMyer's Avatar
Simply put, no you can't use it.
Old Mar 14, 2018 | 11:53 PM
ChuckNTruck's Avatar
The 4wd makes it a bit more complicated for the LS swap but it can be done.
The headers and engine mounts should be the same as the 2wd but the oil pan is very different due to the front differential. i only know of 1 company that makes an oil pan that will work for your swap and thats Milodon part number 31083. With that pan you will have to run a remote mount oil filter also.
I would recommend buying the headers and engine mounts from the same company to prevent fitment issues.
I used Current Performance for all of my LS swap parts in my blazer including having them build me a custom harness and programmed ECM.
Here is an example of a kit that might work for you. The headers say 82-95, But i have the ceramic coated versions installed on my 2002 2wd and they fit perfect.
Milodon 31083K: Street/Strip Oil Pan Swap Kit 1982-92 S10/LS-Series Includes: | JEGS
mirrorimij
Jun 8, 2019 03:34 PM
Bob Z
Mar 20, 2017 12:58 PM
joejiz
Jun 23, 2016 05:27 PM
lizzj70
Jun 23, 2010 06:57 PM
carterx
May 21, 2009 08:30 PM
