Chocolate Milkshake!
Old Nov 4, 2008 | 04:54 PM
  #21
ravenhurst's Avatar
ravenhurst is an unknown quantity at this point
Default RE: Chocolate Milkshake!
Thats what I thought too, the fan should be easier to unmount with the pump hooked up. However, there was nothing I could do to hold that pulley from spinning, even with tension from the belt. I took the whole thing out, took it to O'reiley's, and was just going to replace everything. I couldn't get it off in a vice or anything, without ruining that pulley. When I got there, I brought the part in with me.. lol.. they got a kick out of that. The dude had the huge spanner wrench and lever to hold everything in place and he got if off iwth almost no effort. Go figure. I rented the tools to bring home and mounted the new fan on. Must easier with the right tools for the right job. I took pics of that also, so maybe I can avert someone in the future from having the same problem.
Old Nov 4, 2008 | 10:06 PM
  #22
ravenhurst's Avatar
So this is the thing that vacuum line connects to. Its underneath the battery tray, and the line hooks up underneath it.
Old Nov 5, 2008 | 06:10 AM
  #23
That would be the vacuum actuator for the front axle.
Old Nov 5, 2008 | 03:57 PM
  #24
Hanr3's Avatar
and it goes to teh t-case.
Old Nov 10, 2008 | 04:32 PM
  #25
ravenhurst's Avatar
Alright, here's yet another update to the situation.
I got everything ready to go, installed the distributor per the EDI section here, and she wouldn't crank. The battery started to get low, so I used another Blazer (2004) to juice up the battery. I tried cranking a few times and nothing happened. After about three tries, the electronics in the vehicle started going nuts. Flashing, dimming, etc. I turned the key off and removed it all sounds went away, but the lights (CES, ABS, Battery, etc) were still flashing, and a ticking noise came from the dash. Eventually they all went out, and now, she is completely dead.
Basically I've got a completely dead truck. Turning the key doesn't do anything. Its almost as if the battery was gone.
Thinking we completely drained the battery, I hooked up a overnight charger to it and tried again this morning. Absolutely nothing happened. I also checked both fuse boxes for blown IGN fuses, or the crank one. Nothing seems burned out or anything.
Certainly looking for helpful advice again.
Please also take a look at the Water pump Rem & Inst I posted in the DIY submission section. Feel free to add stuff or critique. Thanks guys.
Old Nov 10, 2008 | 05:40 PM
  #26
Hanr3's Avatar
There is a ground wire from the battery to the engine block. Did you break or disconnect it?
There is also a ground wire ont eh back of the block that attaches to the firewall, and a ground fromt eh battery to the frame. Make sure all three are connected.
Old Nov 10, 2008 | 06:50 PM
  #27
ravenhurst's Avatar
Yes sir, they are all connected. Let me shed a little more light on the subject. I was in a rush posting earlier.
After getting everything assembled, I tried cranking and she was misfiring and not turning over. After the trial and error process of the distributor system, I got it lined up correctly and tried again. It wasn't making the POOF noise of a misfire this time, and it sounded like just a dead battery attempt at starting. The battery guage read a little low, so we decided to push it out of the garage and get some juice from my wife's 2004 Blazer. We let the batteries equalize and tried to start again. It sounded like a champ trying to start, but just would not turn over. This time there wasn't a muffled misfire, it was just sounding like it wasn't getting air or fuel. Doing some quick checks, you could smell fuel on the plugs, and in the exhaust. The throttle body was checked and nothing was stuck closed. I'm not entirely certain if I was getting a spark or not, but all lights and stuff worked. We tried to crank it a couple more times, and she wouldn't turn over. I turned the key off and thats when the electrical anomolies started happening. The lights started to flicker, and fade in and out. I decided to pull the key out and it continued to do this untill they faded and flickered out for good. Now when I put the key in the ignition, to ON, UTIL, START, whatever, nothing happens. Opening the doors doesn't turn on the interior lights. The vehicle is completely dead. My next step is to take the battery to the store and have them check it. Could I have destroyed that battery during the jump while trying to crank it a few times? We had it jumped correctly; it even worked very well for not starting. If the battery checks out good, then its time to break out the multimeter and perform some checks. If its not, then easy fix. Can anyone list the most probable cause of a complete power loss with a good battery to get me started? I'm really starting to get frustrated. Changing the head gaskets went very easy, and putting it back together was a breeze. I guess I'm paying now for the easy trip so far... and of course it has to be the electrical system. Any spark chasers out there, I need you to download your brains and send them to me. To answer Hanr3, both grounds to the back of the heads are reconnected. The ground to the frame was untouched, but I checked anyway and its fine.
EDIT: After talking to the friend that helped me, I asked him how he hooked up the batteries for the jump. I was in the drivers seat when he hooked them up; he said he went straight from battery terminal to terminal, not pos to pos and neg to ground. I guess taking the battery to autozone tomorrow will tell me if the battery was toasted; or if going straight from posts to posts will fry something important.
Old Nov 11, 2008 | 03:45 PM
  #28
Hanr3's Avatar
Its not ideal for batteries to hook them up direct, or rather not ideal for your electrical system. Take a look at your ground wire. Sounds like you may have fried it. That or the positive cable, one of them sounds like toast.
It could be the fuseable link too. You got no power to teh cab, start with the wiring between the cab and battery. Older trucks it goes through the starter.
Old Nov 15, 2008 | 07:50 PM
  #29
ravenhurst's Avatar
My preliminary inspection of the wires;
[ul][*]Negative cable is grounded out to the front frame, the engine block, and the wheel well area. All wires are intact and using a meter for continuity testing, the battery hookup lead showed continuity to all these areas.[/ul][ul][*]Opened up the fuseable link underneath the battery tray. Tested continuity on each bus; wires shot good.[/ul][ul][*]Took the battery to autozone for a test; said it was good to go, but has a low charge. I'm having them charge it and will see if electrics work once its charged and hooked back up.[/ul]
Lets say that my battery wasn't the problem. Where should I look for a potential problem, that would cause nothing to light up in the cab? I'm guessing start from the positive cable to the starter; make sure the starter is intact, or perhaps check resistance through the starter to make sure it isn't ohming out? I would then guess to go from the starter to wherever the power runs from there, maybe the ignition......not sure where it goes from the starter.
Hmm.
I'm going to find a wiring diagram and see the path I need to follow. Are there any common fixes that I could be overlooking?
Old Nov 16, 2008 | 08:10 PM
  #30
ravenhurst's Avatar
No need for further maintenance! Horray!
The auto parts store said the battery was fine, it just had a very low charge. I imagine it drained completely during the bad jumpstart attempt. I hooked up a battery charger to it while it was still uninstalled, left it overnight, and reinstalled the distributor. Took about 5-6 tries of dropping the distributor in to get it lined up right. Stupid EDI design, if you ask me. Anyway, got it in, and she cranked up on the first try.
Bled the coolant system as best I could, got the heater working, and she runs smooth. I did a motor flush and took care of that and remnant milkshake, and am now running Mobile 5w-30 synthetic. She still has hiccups like before the gasket change; but that will be for another thread, when I feel like working it.
Thank you all very very much for the replies, advice, and help. This forum was a great asset and I'll look here to try to offer help to others. I hope my water pump removal and replacement how to thread can help someone out as much as you guys have helped me out.
