Clutch Fluid Mysteriously Leaking
Old Feb 16, 2008 | 12:28 PM
reayb's Avatar
reayb is an unknown quantity at this point
Default Clutch Fluid Mysteriously Leaking
I have an 87 mid size Blazer and it has a hydraulic clutch system. I lost the clutch while driving and pulled it over to take a look. The fluid was all gone but I couldn't tell where it went. It was -40 degrees C outside so I filled it back up with DOT3 and it lasted 4 days before suddenly draining again. I have looked under the pedal, followed the hoses and on the ground.... I can't find where the fluid is going! It is still freezing cold outside so I have 5 minute intervals of looking. If anyone knows where to look I would greatly appreciate it.
Thanks.... Desperate in Canada
Old Feb 16, 2008 | 12:31 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: Clutch Fluid Mysteriously Leaking
have ya checked the slave cylinder? for the clutch... Theres a poss that the metal line froze and cracked on the bottom of the line so when your driving you cant see it leaking cause all the fluid is already is gone.... fill it back up have someone sit in the truck and press and depress the clutch pedal look underneath for fluid dripping....if your in canada, ive been there personally i know it can get damn cold... Ive been there when it was 70 deg below 0 -nuthing was moving!!!!!!!
Old Feb 16, 2008 | 12:41 PM
reayb's Avatar
I'll give it a try... thanks.
MintyMadness
Jul 13, 2011 12:37 AM
Red03
Sep 25, 2008 08:37 PM
bootNreboot
Sep 20, 2008 08:32 PM
blownslt
Apr 18, 2007 11:39 PM
iceman1987
Jan 25, 2007 08:47 PM
